  • 帖子5134
SA517GrA_SA517GrB_SA517GrH_SA517GrS_SA517GrP_SA517GrF_SA517GrE_SA517GrQ压力容器用淬火加回
TEL15603758608 发表于 2021-12-8 15:04:55 | 显示全部楼层 |阅读模式 打印 上一主题 下一主题
压力容器用淬火加回火高强度合金钢板
1、SA517标准包含的材质有:SA517GrA、SA517GrB、SA517GrH、SA517GrS、SA517GrP、SA517GrF、SA517GrE、SA517GrQ。
以上钢板的最大厚度如下所示:详情咨询:15637584700
级别厚度
A、B1.25in.(32mm)
H、S2in.(50mm)
P4in.(100mm)
F2.50in.(65mm)
E、Q6in.(150mm)
2、SA517的炼钢工艺:钢应为镇静钢,并符合A20/A20M标准细奥氏体晶粒度的要求。
3、SA517热处理
3.1 除了3.2允许的做法以外,所有钢板应有应有材料生产厂进行热处理,将钢板加热到不低于1650℉(900℃)温度下,在水或油中淬火,随后在不低于1150℉(620℃)温度下回火,保温时间至少½h。
3.2 但订购无需做3.1条规定热处理的钢板时,生产厂应负责对钢板做消除应力处理,而在随后对钢板做符合于3.1条规定的热处理属于采购方的责任。
4、SA517化学成分
元素成分,%
级别A级别B级别E级别F级别H级别P级别Q级别S
C熔炼分析0.15~0.210.15~0.210.12~1.200.10~0.200.12~0.210.12~0.210.14~0.210.10~0.20
成品分析0.13~0.230.13~0.230.10~1.220.08~0.220.10~0.230.10~0.230.12~0.230.10~0.22
Mn熔炼分析0.80~1.100.70~1.000.40~0.700.60~1.000.95~1.300.45~0.700.95~1.301.10~1.50
成品分析0.74~1.200.64~1.100.35~0.780.55~1.100.87~1.410.40~0.780.87~01.411.02~1.62
P①,≤0.0350.0350.0350.0350.0350.0350.0350.035
S①,≤0.0350.0350.0350.0350.0350.0350.0350.035
Si熔炼分析0.40~0.800.15~0.350.10~00.400.15~0.350.15~0.350.20~0.350.15~0.350.15~0.40
成品分析0.34~0.860.13~0.370.08~0.450.13~0.370.13~0.370.18~0.370.13~0.370.13~0.45
Ni熔炼分析.........0.70~1.000.30~0.701.20~1.501.20~1.50...
成品分析.........0.67~1.030.27~0.731.15~1.551.15~1.55...
Cr熔炼分析0.50~0.800.40~0.651.40~2.000.40~0.650.40~0.650.85~1.201.00~1.50...
成品分析0.46~0.840.36~0.691.34~2.060.36~0.690.36~0.690.79~1.260.94~1.56...
Mo熔炼分析0.18~0.280.15~0.250.40~00.600.40~0.600.20~0.300.45~0.600.40~0.600.10~0.35
成品分析0.15~0.310.12~0.280.36~0.640.36~0.640.17~0.330.41~0.640.36~0.640.10~0.38
B≤0.00250.0005~0.0050.001~0.0050.0005~0.006≥0.00050.001~0.005......
V熔炼分析...0.03~0.080.03~0.080.03~0.08...0.03~0.08...
成品分析...0.02~0.09...0.02~0.090.02~0.09...0.02~0.09...
Ti熔炼分析...0.01~0.030.01~0.10............0.06
成品分析...0.01~0.040.005~0.11............0.07
Zr熔炼分析0.05~0.15③.....................
成品分析0.04~0.16.....................
Cu熔炼分析.........0.15~0.50............
成品分析.........0.12~0.53............
Nb熔炼分析.....................0.06
成品分析.....................0.07
①同时适用于熔炼分析和成品分析。
②可以按一比一,替代部分或全部的钛含量。
③锆(Zr)可以用铈(Ce)代替。当使用铈时,以熔炼分析为准,铈/硫比应为1.5~1.0。
6、SA517力学性能
项目板厚不大于2.5in.(65mm)板厚大于2.5~6in.(65mm~150mm)
抗拉强度,ksi(MPa)115~135(795~930)105~135(725~930)
屈服强度,ksi(MPa)≥100(690)≥90(620)
伸长率(标距2in.或50mm)①≥16≥14
断面收缩率,%矩形试样≥35...
圆形式样≥45≥45
①伸长率的修正见A20/A20M标准
[163music]5_1_1_sharefs.ali.kugou.com/202112081502/4da1347bf178a830c1a7ef32ae0cb6b0/KGTX/CLTX001/5095367f74c58ac0542040211d528075[/163music]
