1 范围:P235GH P265GH P295GH 16Mo3 18MnMo4-5 20MnMoNi4-5 15NiCuMoNb5-6-4 DIWA373 13CrMo4-5 13CrMoSi5-5 10CrMo9-10 12CrMo9-10 X12CrMo5 13CrMoV9-10 12CrMoV12-10 X10CrMoVNb9-12.分类:依照 EN10020,P235GH,P265GH,P295GH 和 P355GH 是非合金钢,其它所有钢是合金特殊钢。
化学成分 钢种 | %质量 | 牌号 | 数字 | C | Si, | Mn | P | S | Al 全 | N | Cr | Cu b | Mo | Nb | Ni | Ti | P235GH | 1.0345 | ≤ 0.16 | ≤ 0.35 | 0.60C- 1.20 | ≤ 0.025 | ≤ 0.015 | ≥ 0.020 | ≤ 0.012d | ≤ 0.30 | ≤ 0.30 | ≤ 0.08 | ≤ 0.020 | ≤ 0.30 | ≤ 0.03 | P265GH | 1.0425 | ≤ 0.20 | ≤ 0.40 | 0.80C- 1.40 | ≤ 0.025 | ≤ 0.015 | ≥ 0.020 | ≤ 0.012d | ≤ 0.30 | ≤ 0.30 | ≤ 0.08 | ≤ 0.020 | ≤ 0.30 | ≤ 0.03 | P295GH | 1.0481 | 0.08- 0.20 | ≤ 0.40 | 0.90C- 1.50 | ≤ 0.025 | ≤ 0.015 | ≥ 0.020 | ≤ 0.012d | ≤ 0.30 | ≤ 0.30 | ≤ 0.08 | ≤ 0.020 | ≤ 0.30 | ≤ 0.03 | P355GH | 1.0473 | 0.10- 0.22 | ≤ 0.60 | 1.10- 1.70 | ≤ 0.025 | ≤ 0.015 | ≥ 0.020 | ≤ 0.012d | ≤ 0.30 | ≤ 0.30 | ≤ 0.08 | ≤ 0.020 | ≤ 0.30 | ≤ 0.03 | 16Mo3 | 1.5415 | 0.12- 0.20 | ≤ 0.35 | 0.40- 0.90 | ≤ 0.025 | ≤ 0.010 | e | ≤ 0.012 | ≤ 0.30 | ≤ 0.30 | 0.25- 0.35 | _ | ≤ 0.30 | _ |
熔炼分析界限值所允许的成品分析偏差 元素 | 根据表 1 的熔炼分析规定数值 %质量 | 成品分析的允许偏差a %质量 | C | ≤0.23 | ±0.02 | Si | ≤0.35 | ±0.05 | >0.35--≤1.00 | ±0.06 | Mn | ≤1.00 | ±0.05 | >1.00--≤1.70 | ±0.10 | P | ≤0.015 | +0.003 | >0.015--≤0.025 | +0.005 | S | ≤0.015 | +0.003 | Al | ≥0.010 | ±0.005 | B | ≤0.003 | ±0.0005 | N | ≤0.020 | +0.002 | >0.020--≤0.070 | ±0.005 | Cr | ≤2.0 | ±0.05 | >2.00--≤10.00 | ±0.10 | Cu | ≤0.30 | ±0.05 | >0.30--≤0.80 | ±0.10 | Mo | ≤0.35 | ±0.03 | >0.35--≤1.10 | +0.04 | Nb | ≤0.10 | ±0.01 | Ni | ≤0.30 | +0.05 | >0.30--≤1.30 | ±0.10 | Cr+Cu+Mo+Ni | ≤0.70 | +0.05 | Ti | ≤0.03 | ±0.01 | V | ≤0.05 | ±0.01 | >0.05--≤0.30 | ±0.03 | a 如果一炉钢进行多次成品分析且单个元素确定值超出了化学成分的允许范围,只 允许此值超出最大允许值或低于最小允许值,对于一炉钢二者不能同时。 |
力学性能
钢种 |
通常交货状态 b,c |
产品厚度 t,mm |
室温拉伸性能 | 最小冲击功,KV, J,℃ | 屈服强度ReH MPa, 最小 |
抗拉强度 Rm
MPa | 断后伸长率A % 最小 |
-20 |
0 |
+20 |
名称 |
数字 | P235GH | 1.0345 | d +N | ≤16 | 235 | 360--480 | 24 | 27 | 34 | 40 | 16 | 225 | 40 | 215 | 60 | 200 | 100 | 185 | 350--480 | 150 | 170 | 340--480 | P265GH | 1.0425 | d +N | ≤16 | 265 | 410--530 | 22 | 27 | 34 | 40 | 16 | 255 | 40 | 245 | 60 | 215 | 100 | 200 | 400—530 | 150 | 185 | 390--530 | P295GH | 1.0481 | d +N | ≤16 | 295 | 460—580 | 21 | 27 | 34 | 40 | 16 | 290 | 40 | 285 | 60 | 260 | 100 | 235 | 440—570 | 150 | 220 | 430--570 | P355GH | 1.0473 | d +N | ≤16 | 355 | 510—650 | 20 | 27 | 34 | 40 | 16 | 345 | 40 | 335 | 60 | 315 | 490—630 | 100 | 295 | 480—630 | 150 | 280 | 470--630 | 16Mo3 | 1.5415 | e +N | ≤16 | 275 | 440—590 | 22 | f | f | 31 | 16 | 270 | 40 | 260 | 60 | 240 | 430—560 | 100 | 220 | 420—570 | 150 | 210 | 410--570 | | | | | | | | | | |
钢种 |
产品厚度 t,mm |
下列温度(℃)时的最小 0.2%屈服强度RP0.2,MPa |
50 |
100 |
150 |
200 |
250 |
300 |
350 |
400 |
450 |
500 | 名称 | 数字 | P235GH | 1.0345 | ≤16 | 227 | 214 | 198 | 182 | 167 | 153 | 142 | 133 | -- | -- | 16 | 218 | 205 | 190 | 174 | 160 | 147 | 136 | 128 | -- | -- | 40 | 208 | 196 | 181 | 167 | 153 | 140 | 130 | 122 | -- | -- | 60 | 193 | 182 | 169 | 155 | 142 | 130 | 121 | 114 | -- | -- | 100 | 179 | 168 | 156 | 143 | 131 | 121 | 112 | 105 | -- | -- | 150 | 164 | 155 | 143 | 132 | 121 | 111 | 103 | 97 | -- | -- | P265GH | 1.0425 | ≤16 | 256 | 241 | 223 | 205 | 188 | 173 | 160 | 150 | -- | -- | 16 | 247 | 232 | 215 | 197 | 181 | 166 | 154 | 145 | -- | -- | 40 | 237 | 223 | 206 | 190 | 174 | 160 | 148 | 139 | -- | -- | 60 | 208 | 196 | 181 | 167 | 153 | 140 | 130 | 122 | -- | -- | 100 | 193 | 182 | 169 | 155 | 142 | 130 | 121 | 114 | -- | -- | 150 | 179 | 168 | 156 | 143 | 131 | 121 | 112 | 105 | -- | -- | P295GH | 1.0481 | ≤16 | 285 | 268 | 249 | 228 | 209 | 192 | 178 | 167 | -- | -- | 16 | 280 | 264 | 244 | 225 | 206 | 189 | 175 | 165 | -- | -- | 40 | 276 | 259 | 240 | 221 | 202 | 186 | 172 | 162 | -- | -- | 60 | 251 | 237 | 219 | 201 | 184 | 170 | 157 | 148 | -- | -- | 100 | 227 | 214 | 198 | 182 | 167 | 153 | 142 | 133 | -- | -- | 150 | 213 | 200 | 185 | 170 | 156 | 144 | 133 | 125 | -- | -- | P355GH | 1.0473 | ≤16 | 343 | 323 | 299 | 275 | 252 | 232 | 214 | 202 | -- | -- | 16 | 334 | 314 | 291 | 267 | 245 | 225 | 208 | 196 | -- | -- | 40 | 324 | 305 | 282 | 259 | 238 | 219 | 202 | 190 | -- | -- | 60 | 305 | 287 | 265 | 244 | 224 | 206 | 190 | 179 | -- | -- | 100 | 285 | 268 | 249 | 228 | 209 | 192 | 178 | 167 | -- | -- | 150 | 271 | 255 | 236 | 217 | 199 | 183 | 169 | 159 | -- | -- | 16Mo3 | 1.5415 | ≤16 | 273 | 264 | 250 | 233 | 213 | 194 | 175 | 159 | 147 | 141 | 16 | 268 | 259 | 245 | 228 | 209 | 190 | 172 | 156 | 145 | 139 | 40 | 258 | 250 | 236 | 220 | 202 | 183 | 165 | 150 | 139 | 134 | 60 | 238 | 230 | 218 | 203 | 186 | 169 | 153 | 139 | 129 | 123 | 100 | 218 | 211 | 200 | 186 | 171 | 155 | 140 | 127 | 118 | 113 | 150 | 208 | 202 | 191 | 178 | 163 | 148 | 134 | 121 | 113 | 108 |
热处理准则表 A.1 给出了热处理温度的参考数据。消除应力退火见附录 B。
表 A.1 热处理温度的准则
钢种 | 温度℃ | 名称 | 数字 | 正火 | 奥氏体化 | 回火 b | P235GH | 1.0345 | 890—950a | -- | -- | P265GH | 1.0425 | 890—950a | -- | -- | P295GH | 1.0481 | 890—950a | -- | -- | P355GH | 1.0473 | 890—950a | -- | -- | 16Mo3 | 1.5415 | 890—950a | -- | c |
| 【公司】舞钢市鑫泽钢铁销售有限公司
【姓名】王笛
【手机】13783759908
【微信】13783759908
【固话】0375-8201707
【优势】现货充足,规格齐全,享有钢厂最大优惠政策。专业数控切割、加工钢板异形件、法兰等。现可供切割加工件专业范围8-400mm厚,数控切割加工,切割精度高,切割件质量稳定可靠。
诚者为人 信者为商 , 我一直都在!随时恭候您的来电!
